The temp sensor is in the mechatronic assembly that bolts to the valve body, i dont believe its a separate part to replace.
I would rebuild the valve body first, put a zip gen2 kit through, new solenoids, mech and pump seals, steel pan, filter and gasket, then you should be able to reset the adaptations.
