Oil cooler sitting in the V leaking coolant into the void between the two banks, this then either evaporates or drains down the back of the block externally when driving.
Plastic fitting into the block can crumble if disturbed, but then you'd lose all the coolant at once.
Head gasket - unlikely if engine is still running well, being a diesel they run high compression so a head gasket leak is pretty evident.
