Did you let the system charge up and sit idle between each test? If for example you went Access->Normal, the system is going to need to run a while to re-charge the reservoir. If you went Normal->Offroad in that time then you're going to be waiting longer than if you did it with a full and idle system.
For giggles I'll time mine today.
