Results 1 to 10 of 13
Thread: Help need a new tire x 1 will it stuffed my transfer case.
    Feb 2014
    Adelaide
    Hi all I have heard that you can stuff your transfer case of you put a new tire on when the other 3 are worn. Is this the case. I am in WA 2500km from home and have a small leak. In one Which needs to get sorted I am arriving at Busselton tomorrow who have a good selection of tire shops should I replace the 2 rear ones or all 4 they where going to be replaced when I got home.
    The spare is ok but was also going to be replaced when I got home also. Some advise would be helpful cheers all
    2010 D4 3litre twin turbo brand new motor 5km old on a 100,000km car. Kaymar rear bar, ARB front bar, Hannibal roof rack, Hella Predator Spot lights, long rand fuel tank, Traxide battery management. touring weapon.
    Mar 2016
    Quote Originally Posted by coopers1969 View Post
    No. The transfer case will care when a pair of tyres at one end vary significantly to the other axle, but a difference one one axle only will be accounted for by the diff. It’s still not a great idea.
    2007 Audi RS4 (B7)
    Back down the hill.
    Fix the leaky one, even if it needs a tube. Sort the tyres when you get home. JMO.
    Feb 2014
    Adelaide
    Will a tube work if I have the Land Rover TPMS fitted
    NSW SW Slopes
    Fitting 1 new tyre whilst the other 3 are worn won't cause any issues providing it is the same size specification and the same construction, ie passenger or light truck.
    Back down the hill.
    Is the monitor removable?
    Feb 2014
    Adelaide
    No I don’t think so it is the factory fitted one.
    Apr 2012
    Whyalla, SA
    I'd suggest this isnt quite so Graeme - from experience.
    Same brand, same model, same size, same contruction in a HT or similar will be fine becuase the tread depth new is quite low anyway.
    If running a chunky AT or above, then depending on the wear of the other tyres - I can assure you the vehicle WILL start to react to it. Especially when cornering etc
    I had to fit a brand new spare to a vehicle with 80% worn rubber all round and the DSC could be felt influencing the vehicle.
    Mar 2016
    Valid point. Diffs won’t care but the difference in size can send the DSC into a quandary.
    2007 Audi RS4 (B7)
    NSW SW Slopes
    My L322 didn't care when one 30" tyre was test-run with the other three almost 32", obviously less sensitive than D4s.
    Notwithstanding any DSC activation, the diffs wouldn't be bothered by 1 new tyre and 3 worn ones.
