Results 1 to 10 of 15
Thread: some Ethanol info
    Perth, HighWycombe
    some Ethanol info
    I found this site, some will find it interesting.
    http://www.fcai.com.au/ethanol/
    Federal Chamber of Automotive Industries (FCAI)
    Mick
    Caboolture.Qld
    I worked in PNG for years and we had ethanol in the fuel there, I drove MQ Nissan Patrol and I didn't notice any drop in performance after the ethanol was introduced, what I did notice was that it ate my carby. true
    Quote Originally Posted by RobHay
    One of the problems with ethanol is that it is hygroscopic - that is, it absorbs water. I can just visualise it sucking water out of the air in a place like PNG, and, of course, this will help things like carburetters to corrode.
    Jun 2003
    Launceston, Tasmania
    One issue with ethanol is that As I understand it, it can have a detrimental effect on fuel pums in older vehicles (coming from a mate with a Willys jeep). Apparently there is a diaghphram in them that reacts with ethanol.
    Ok is the fuel is labeled as containing it, not so good if it isn't
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    LoadedDisco Guest
    So out of all that would it be ok to use Ethanol in a new Disco.
    Any Help.
    Narrogin WA
    Quote Originally Posted by LoadedDisco View Post
    Any Help.
    Ethanol fuel, despite all the bulldust the Govt. tells us, is the worst fuel to use. As JDNSW points out it absorbs water and we all know water doesn't burn! The calorific value of ethanol is very poor, so petrol engines will lose power and use more fuel. The cost to the environment of producing ethanol far outweighs any gain.
    Why is it being pushed by the Govt? Because the farmers' lobby, especially in the USA, want to be paid to grow corn that nobody really needs - and what is good for George W is good for Australia, if Mr Howard's past record is any indication.
    Avoid ethanol like the plague, if you love your Rover!
    Quote Originally Posted by chazza View Post
    In about the 1950s, water/alcohol injectors were flavour of the month. I think they had been found useful in preventing the supercharged engines in fighter planes from overheating or pre-ignition problems at sea level.
    My father bought one and fitted it to a 30cwt Commer truck and designed and made a much better one which he fitted to our 1936 Plymouth.
    It added a small amount of metho and water to the fuel/air mix at the carby.
    I'm not going to claim that it worked, but one January as we were towing an 18ft caravan up the Pacific Highway, it was so hot that truck tyres had rolled up sections of melted bitumen and there were current model Holdens pulled up on the side of the road with their bonnets up and steam gushing out of their radiators.
    The old Plymouth, which didn't even have a water pump but just relied on convection to circulate the water showed no signs of getting hot.
    I think the general consensus though was that it was a waste of time.
    Water may not burn, but in certain circumstances it might be a useful addition to the fuel/air mixture as some sort of aid to combustion (especiallly if your LR is fitted with a high compression supercharged aircraft engine).
    Brisbane, Inner East.
    They were used then because our petrol was of relatively low octane and many post-war cars needed higher octane fuel, hence the introduction of "super" petrol about 1956-57. Water injection prevented the pinging you got when setting to manufacturer's specs on "standard" petrol. A side effect was that water injected engines were always clean inside when you pulled the head for the regular decokes and valve grinds needed then.You never found the heavy build-ups of carbon on the pistons and combustion chambers normally found in standard engines of the time.
    The sales & use of these items faded away in a couple of years after the introduction of "super" petrol.
    URSUSMAJOR
    Perth, Western Australia
    From the most basic thermodynamics, putting a bit of water in the cylinder with the fuel / air mixture can give you more expansion as the water turns to steam and hence substantially more volumetric efficiency. The same reason why power stations use steam cycles instead of air or direct combustion.
    Unfortunately, water injectors and their plumbing tend to corrode and block up plus water in the crankcase isn't nice (if say 1 cylinder fails to fire). It also adds an extra level of complexity to engines - which car makers tend to avoid but car enthusiasts love.
    (Edit) Forgot to add that water also lowers the exhaust temp which means you can run higher CR without knocking. This is probably the main advantage
    Ethanol from corn has a greater environmental cost than what it saves, or at best breaks even. However, ethanol from sugar cane as in Australia or Brazil has a positive environmental benefit, at least as far as the CO2 budget goes. The US and Australian situations are different because the crops used are different.
