Originally Posted by
DRUT
Has anybody got any after market ideas for underbody protection for a 99 defender tray back. Preferably stuff I an get made or make myself to save $$$$. Looking for engine, gearbox and t'fer case and steering gear protection. Its only a tourer but better safe than sorry. I have Bearmach diff protetion front and rear already but am looking for cheaper ideas for other areas.
DRUT
I have difficulty seeing anything apart from the front diff and steering links that is at all at risk. Certainly never damaged anything except the track rod myself (in 400,000km including a lot of off road). Everything else is pretty well tucked up - the front axle will shield nearly everything. I am not sure whether the Defender has a guard on the fuel tank, but if not a skid plate there could be an idea - although the plate under my fuel tank has no dents in it, it has the odd bit of paint scraped off.
For the steering gear the best solution is probably a heavy track rod (several varieties available or you can get a reinforcing tube that goes over it - I've also seen advertised a bracket on the diff that stops it bending too far, but I'm not keen on that idea) and possibly drag link, although the drag link is fairly well up out of danger.
I have seen u-joint guards advertised (no point in having them on the front unless you make a habit of driving backwards), but they look to me like they would cause more trouble than having the open joints - imagine trying to untangle a bit of fencing wire wrapped round that, jammed between it and the joint. Be bad enough with small sticks and other kindling, which could ignite from friction. The rear prop shaft is prone to damage if you really try, but it is difficult to see how it could be protected without reducing clearance - remember it travels down a long way on rebound.
