Results 1 to 8 of 8
Thread: Oil cooler gasket alternative
    May 2018
    Has anyone had any experience using anything other than the metal gasket for the oil cooler? I am thinking of using the sump sealant used for the 300tdi engine (black permatex)
    So obviously oil and heat resistant
    Cheers!
    Oct 2012
    Quote Originally Posted by Vouge SE View Post
    Cheers!
    Risk would be getting some of that direct into the oil galleries whereas at least on a sump anything might be picked up into the oil pickup strainer. Not sure you could ever do it neat enough.
    May 2018
    I’m thinking I’ll put it on the oil coooler side then mate it to the block. I have the oil cooler all out looks pretty doable
    Sep 2014
    Baldivis WA
    Oil pressure in the sump is (nearly) atmospheric, so a flexible type sealant would be OK, whereas at the oil cooler it would be a great deal higher, plus the pressure from the coolant side. There's a reason for the metal gasket, imho I wouldn't be trusting a hand applied bead of gasket sealant for the oul cooler, but each to their own I guess....
    Apr 2012
    Whyalla, SA
    If it was even remotely suitable it wuld be installed during engine build - because its cheaper than having a gasket made.
    Dont stick "goop" where it feeds critical oil systems
    Jul 2013
    Im not 100% on the oil flow, but a reasonable thought is the cooler is the last run before dropping back to the sump. Sealant in my mind is therefore not likely to block galleries in the engine, but the cooler will be a lot finer and you will risk getting sealant stuck in there first.
    New gasket, make sure the mating faces are nice and flat and cleaned properly. Shouldn't have too many issues
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by shanegtr View Post
    It can't be. There'd be no pressure to push the oil through the cooler and there's no way to collect all the spill from the bearings to channel it through the cooler.
    As the oil cooler is an integral part of the filter assembly it stands to reason it's pre or post filter. Either way it's on the pressure side of the lubrication system.
    Jul 2013
    Quote Originally Posted by BradC View Post
    Of course, your dead right there. Must have been having a brain fart when I posted that
    Shane
