Thread: Name of Carpentry/Cabinet Fixing
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Just wondering if anyone knows the name of a carpentry-cabinet fixing? The fixing is used to secure the legs of single bed made out of pine. There is a small length of round steel rod that has a threaded hole drilled through the side of the rod. The threaded rod is then place in a hole drilled in the bed base. A hole is then drilled through the leg where a bolt slides through and engages with the threaded rod. This tightens the bed leg to the base
    If someone can identify the name of the bolt I could then set about trying to identify and track down a local supplier. Thank you
    Kind regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    I went out and found some of the fixings I am attempting to get identified and I took some photographs. Hopefully it will jog people's memories and a name for them will be found so I can buy some. Otherwise I will be off to the local steel place and find out if they sell round bar mild steel with the same diameter.
    Kind regards
    Lionel
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    I performed an Google Image search using one of the photographs and they are called either cross barrel nuts or cross dowel nuts. The Lord helps those who help themselves.
    Kind regards
    Lionel
    Back down the hill.
    I'm no great shakes as a carpenter, but I am reasonably experienced at converting precision milled timber into firewood. The only places I've come across those type of fastener/fixing, is on flat pack furniture, so thought they were cheap, dodgy Chinese fixings. I wasn't aware they were a legitimate cabinet makers' fastening.
    Mar 2010
    Queensland
    12.97 MB
    Hello Ian,
    Thank you for the reply. It was the first time I had come across them used on furniture. I have come across plenty of the cam nut connectors before in flat packs. When I took the furniture apart I then promptly lost the barrel nut part of the set. That hole in the universe that takes 10 mm spanners and just one sock visited my shed. I have been using an adaptation of that style of fixture when I make 100mm x 50 mm pine 'sleeper' engine dollies for things like my Chevrolet 216 cubic inch six cylinder motor and the Perkins 6354 diesel. Motors that I am not comfortable with hanging off an engine stand.
    I will post up a photograph after I visit the engines again. The frames have between 4 or 6 castor wheels - depending on the weight of the engine, so I can move the engines around. The same technique is used to fix the timber frame between the furniture barrel/dowel cross nuts and my use of 12 mm cuphead bolts and holes drilled in the sides and ends of the timber frame of my engine dollies. For some strange reason I want to totally secure the 515 kilograms of Perkins motors when I am working on them.
    Kind regards
    Lionel
    Ipswich QLD.
    Hello Lionel, I hate to say it, but maybe have a look at Bunnings. Taskmaster M8 Electro Brass Cross Connector Dowel - 4 Pack - Bunnings Australia
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by Killer View Post
    Cheers, Mick.
    Hello Mick,
    thank you for the notification. I did look at the Bunnings offering and I could not find a match to the dimensions of the cross dowel I removed out of the four left in one end of the bed in question. As I am in no hurry, I just did some more digging on the interwebby and order a close match to the original ones as a kit. Patience is a virtue after all!
    Kind regards
    Lionel
