Sounds to me like significant cam chain rattle in the foreground. The whistle in the background is the turbo spooling up. The rattle would be 1st concern, I think the timing chain guides are worn out, running against the metal backing plate. These engines run a timing belt on the front of the engine from the crank to the outer (exhaust) cam on each bank, then a chain from there to the inner (inlet) cam on each bank. The tensioner sits vertically up between the camshafts, one on each bank, keeping tension on the short chains. When the guide wears out, the chain runs along the backing of the guide, and tension is not what it should be. Risk is if you snap the chains or they jump a tooth or two, valves will hit pistons as they're an interference engine. Relatively easy to replace the tensioners, more costly if they break. The hardest part is getting the manifolds off, as the injectors have to come out, so you need new crush washers for that, and the crossover pipe and throttle Y piece are a fun challenge to get out. 180k km seems a little low for timing chains, but not unheard of
