Under the nut at the end of the curved spring. You might need to fix the insulation on the black lead.
See Illustration #1066 from our guide
Howdy folks,
I took this distributor apart many months back to fit a new points set. I took plenty of pictures , downloaded them to my pc which has now carked it. Can anybody tell me please where the two wires attach to, orange and black.
Thank you,
1957 88 Petrol (Chumlee)
1960 88 Petrol (Darwin)
1975 88 Diesel (Mutley)
Ah, so both go to the same point, got it and
understood re the insulation on the black wire.
many thanks for the diagram and taking the time to reply.
not having a great time recently so this helps me a lot.
many thanks,
David.
Under the Nut may be a bit misleading.
Good explanation here.
25D4.
Points Types (mgb-stuff.org.uk)
whitehillbilly
Instead of trying to fix the insulation ( it will fail when it is least convenient, ask me how I know ), get yourself one of these, although you need to check fitment as they are not all the same.
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
