Thread: Auto STOP/START
    Jun 2024
    Auto STOP/START
    Is it possible to negate having to engage the ‘A’ button every time I start up, on a 2023 Evoque ?
    May 2003
    On The Road
    Wow... still. LR just dont learn.
    Pics?
    Nov 2015
    Black Rock
    Could there be a setting in the CCF to toggle it off? Do current models have a CCF?
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Queensland
    I have not tried this on a Land Rover, but on a number of other makes, if you disconnect the sensor on the negative ( - ) terminal on the cranking battery, it will permanently disengage the STOP/START function and will also stop the alternator from dropping to low voltages.
    By the alternator running at a higher voltage, your cranking battery will be better charged at all times and should last longer.
    NOTE, on some makes, disconnecting this sensor can cause error messages. If this occurs, you will need to reconnect the sensor.
    Jun 2024
    Drivesafe
    Thank you’drivesafe’
    How do I identify the Stop/Start cable at the - battery terminal?
    Queensland
    Quote Originally Posted by Simonp View Post
    Hi again Simon, there is NO STOP/START specific cabling at the cranking battery, you are simply disconnecting the sensor.
    There will be a two wire plug and socket near the sensor, just unplug it and see how you go.
    NSW SW Slopes
    If there is a start-stop capacitor like in the later L405s then disconnecting the sense wire from it should do the trick. A setting in the CCF of MY17+ L405s can be changed to default to off using an IIDtool so possibly also in the Evoque.
