I wonder if/for how long consumables will be available.
I dunno if they’re any good, but Aldi, in Victoria at least, have a cutter on sale June 29. $299.
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
 Super Moderator
						Super ModeratorMy cheap chinese plasma cutter has a plethora of consumables available on ebay and aliexpress. When it arrived with some **** random handpiece that used hard to find bits I just replaced the cable and handpiece with a generic E-bay special and it's been apples since. The expensive bit is the inverter, and at least with Aldi you get a year warranty. Mine came with a bench warranty. The warranty expired when it left the assemblers bench. 12 years later it still works, and I still have a small pile of consumables thanks to cheap chinese manufacturers.
Just do it!
Have to say I have a couple of Aldi things. One beauty is a petrol powered pressure washer with a Chonda engine. It's brilliant, and everything like nozzles and handpieces are available all over, not that I've needed any apart from a nozzle that I hadn't secured properly. No idea where that went. But I have bought accessories, like a drain snake, from one of the red tool stores that fit fine.
Aldi stuff is usually pretty good, says me, touching wood for my washing machine.
JayTee
Nullus Anxietus
OKApotamus #74
Three years for this one. And it'll cut up to 12mm, which makes it overkill for what I want it for..
JayTee
Nullus Anxietus
OKApotamus #74
Proper cars--
'92 Range Rover 3.8V8 ... 5spd manual
'85 Series II CX2500 GTi Turbo I :burnrubber:
'63 ID19 x 2 :wheelchair:
'72 DS21 ie 5spd pallas
Modern Junk:
'07 Poogoe 407 HDi 6spd manual :zzz:
'11 Poogoe RCZ HDI 6spd manual
First one to pop up on a quick search.
ROSSI CUT40 Mk III Portable 40A Plasma Cutter Machine, with Accessories
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberJayTee
Nullus Anxietus
OKApotamus #74
