Thread: 2.7 TDI Fluid costs
    Jan 2013
    Yarra Valley, Victoria
    2.7 TDI Fluid costs
    Friends, I have a newly-acquired D4, 2.7 TDI, coming up to 160k km. Searching for the correct spec engine oil I arrived at Fuchs (Oz company) Titan GT1 C1 5W30. Surprised at the cost though - $113.50 per 5 litres. And of course 5 litres isn't quite enough so I had to buy 2.
    Similarly, correct spec power steering fluid, Penrite PAS fluid Semi Synthetic, set me back $50.80 for 1 litre. Are these prices in accord with general experience?
    TIA, Rob S
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    at those klms i would be using 5w-40. i use penrite so dont know if Fuchs have one...
    the oil specs for AU products vary from the SA specs although the climate seems very similar. au spec is 5w-30 and SA spec is 5w-40 i am reliably informed...
    timing belts been done ?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    St Helena,Melbourne
    1.13 MB
    Yes use 5w40 as inc said and check if the belts have been done,I would also change the oil pump even though it's not a problem in the D4 but the latest version will improve oil pressure.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2016
    Blackstone
    I'm not sure if the oil specs are the same for the 2.7 D3 and D4.
    MR Automotive used Valvoline Synpower FE 5W30 when I had my vehicle serviced there.
    I buy 20l drums when they are on special. Supercheap have it on special for $232.99 for 20 litres at the moment.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    St Helena,Melbourne
    1.13 MB
    Penrite HP5 5w40 comes in a 6L bottle for around $100 or less, you need 5.7L so a 6 or 7ltr bottle is ideal.
    1974 VW Kombi bus
    Mar 2016
    Look for a special at supercheap and buy a couple. I can normally snag it for around $60-70. Which reminds me, oil change this weekend. Currently doing 10,000km a quarter 🫨
    2007 Audi RS4 (B7)
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    I buy at Repco once a year at the Easter 30% sale. Generally 20L for ~$190 HPR5.
