I have Koni raids on the rear of my 110, set them to the lowest adjustment when I fitted them 2 years ago thinking I'd adjust if necessary or maybe to experiment. I have never bothered the ride has been fantastic whether loaded or not so I haven't changed them.
You sound like you run a bit heavier than I do but I would try them low and adjust up if needed, although front is more difficult to remove and adjust.
Cheers Discofender
