Results 1 to 10 of 13
Thread: Crank Angle Sensor
    May 2009
    Tatura, Vic
    Crank Angle Sensor
    Mine still has the original crank angle sensor and has done 240,000 Kays.
    I am doing a double Simpson Desert crossing next month, so I reckon a CAS change would be a good idea.
    I priced a genuine one today. This is out of the question as I have sold all my children and only have one kidney left to sell.
    These sort of thing aftermarket, being very cheap, worry me.
    Any advice on what to get. I am looking at a brand called Intermotor which the seller says is OEM quality.
    However, most sellers will say anything to get your business.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    NSW SW Slopes
    My only recollection of failing TD5 crank position sensors weren't the sensor at all, just the usual oil in ecu connector issue.
    Bairnsdale enjoying the rural view no rooftops to see here
    Quote Originally Posted by d2dave View Post
    Dave mine had done 400000 ks still on the original cas and I just used to carry a second hand one with me just in case
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Apr 2016
    Country Vic.
    I've had a few Intermotor bits and pieces over the years. IIRC mainly on my old Rover cars.
    My thinking on this topic would along the lines of:
    I've been reading and watching a fair amount of info re Landrover/TD5/Tdi. Patterns form when it comes to parts replacement.
    eg. TD5 exhaust manifolds, I put up with a broken stud, slight leak for a while on the brothers TD5 whilst I had it. Brother wanted to get a $200 stainless manifold off ebay. My 'Spidey Senses' smelled something off. Having read a bit about them, it was obvious that pretty much 100% failed at some point. Same with Engine mounts .. read the remarks where many cheaped out and they failed, so incurring the extra cost of doing it again.
    One thing that doesn't seem to a problem tho is the commonly bought CPS. I strongly doubt that all those that I've read about have gone with a $600-700 genuine LR boxed unit. They'd have gone with the more sensible $60-$80 version(depending on where it was sourced). Can't recall any complaints that these sensibly priced CPS units are failing en masse
    I'd just go with the one you get, the two common makes seem to be Intermotor and Delphi.
    Also, if it were me doing the trip, I'd be keeping it as a spare in the spares/parts/tools kit, not changing it for the sake of it. Familiarise yourself with how to change it. As long as you have a nanocom(or Hawkeye) to diagnose it's death(if it does), you shouldn't have to worry.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jul 2014
    west of Transylvania
    The real OEM is Lucas SEB355 that's for sure. That "OEM" suffix means almost nothing these days cos many suppliers are using it wrong especially that "oem quality" which IMO is a scam, it appears for most of the various engine parts sold on aliexpress, i'd not care if it was about a bush or bearing or something similar but when it comes to a vital sensor it's a different story
    Apr 2024
    fnq ish
    Quote Originally Posted by AK83 View Post
    They're pretty much just a coil of wire with a magnet down the guts of it.
    It "should" be the most reliable sensor on the D2. <- just jinxed myself
    even so, I carry a spare as it's pretty much the only sensor that will leave you stranded ? (TPS maybe as well)
    Sep 2010
    The Hills.
    152.79 MB
    I got one from a Jag wrecker. Same thing. It’s just a Hall effect sensor. I would definitely pay attention to the wiring going to it though. Mine got brittle and broke, causing a failure to proceed.
    A second hand one would be good to have in your spares box though. No, I don’t remember what model Jag. Cost me $35 I think. Don’t ask me why I needed it
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    NSW SW Slopes
    Quote Originally Posted by FNQLR View Post
    I drove my manual TD5 through stop-start Canberra afternoon peak hour traffic with a dead TPS, working up speed by idling though the gears until 40 kph when CC was used to go faster. Not towing anything though.
    Apr 2024
    fnq ish
    I'm so going to try this. probably not in peak hour traffic though
    My CC kicks in at 20kph (Shack tune)
    Mar 2020
    I'd be checking/replacing the wiring over the sensor. Like I'm sure they fail occasionally but mostly it's the brittle AF wires snapping.
