Results 1 to 4 of 4
Thread: Tyre winder with seats down
    Oct 2016
    Perth, AU
    Hi all
    I have a set of rear drawers that go in and out of the car as needed for camping. On bigger trips the rear seats will come out too.
    For shorter weekenders, I’d prefer to leave them in (less hassle) but face the problem of access to the spare tyre winder.
    The drawers (Drifta) have a hole to access, however is there some trick I’m missing to get the extension rod to pass between the seats? Feels like there is nowhere near enough space?
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Oct 2011
    Fremantle WA
    Quote Originally Posted by veebs View Post
    Hi all
    It is certainly tight. I get around it by having a "permanent" socket and shaft in situ. Still might not work for you if the shaft wobbles around and misses the bottom hole in the drawers?
    Jan 2012
    The plastic trim on the seat hinge can also be removed to make more space for the extension bar…
    Jun 2008
    McMinns Lagoon NT
    Hi all
    A 3/8" extension fits between my D3 seats. I have it in there when using my home made floor board on longer trips which covers the seats.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
