Results 1 to 9 of 9
Thread: Defender 300 TDI - LT230
    Jan 2010
    Perth S/W
    I need to replace the T'case in my 97 130 Defender .
    Have looked at the videos etc.
    What is the best practice with the larger sump [ flat bottom ]
    Should I make a plate to fit the jack , bolt it on , or does it balance ok without it .
    I have the original cover , can use that too and make the plate to suit that .
    Anyone's experience would be greatly appreciated .
    Sep 2010
    The Hills.
    152.79 MB
    If you search Mike’s channel I’m pretty sure you will find a jig he made. I don’t have time to look so I’ll just post this as a starting point.
    https://youtu.be/NSUlENy_y5E
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Oct 2007
    Wantabadgery, N.S.W.
    Here ya go mate......
    LT230 transfer box lifting bracket.pdf
    I have built one of these. it made removing the transfer very easy. I took the turntable/ lift plate off the trolley jack and fittied the lifting bracket to the jack in it's place using a short bit of suitable pipe welded on to the base.
    Don.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Don 130 View Post
    Don.
    Cool. I might just pinch that as well.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jan 2010
    Perth S/W
    Got the old one out with a hydraulic lift table , balanced quite well on a block of wood with the flat sump cover .
    Quite doable on my own . Hardest part was 10 years of oil & dust & mud to scrape off under the Landy , looks nice now .
    Hope the other one goes in as well .
    Sep 2010
    The Hills.
    152.79 MB
    If you can fit some dummy studs to guide it on it's good, cos it protects the seal etc.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jan 2010
    Perth S/W
    Yes , the studs worked well getting it off .
    Oct 2007
    If I remember correctly, 10 x 100mm gal coach bolts with the heads cut off and a slot cut in the bare end with a hacksaw (allows use of screwdriver to get them out when the new TC is fitted)
    Green hardware shop.
    Don.
    Jan 2010
    Perth S/W
    I used quite long ones , too long , I had to remove them before I could lower the T case .
    They need to be longer than the shaft that feeds through the seal so as not to risk damaging it .
    Britannica resto recommended one bolt to retain the head so as not to risk the T case sliding off unexpectedly , probably a wise precaution , could end very badly .
