I just mounted my biig light bar in the bumper opening above number plate, you could use rivnuts but i just used some tek screws.
As for antenna I got this one LAND ROVER DISCOVERY 3 / 4 / RRS ORIGINAL DESIGN UHF / CB AERIAL ANTENNA BRACKET | eBay
Question: I'm after brackets that I can install through the grille of the L320 (2) to mount a light bar and or an antenna base. I have a quote from a mechanic but find that very difficult to accept without checking for alternatives.
Appreciate any feedback, thank you!
Regards,
Sascha
Thank you Haydent. Much appreciated.
Re light-bar, great idea! Is there any bounce on uneven roads or is it rock solid? Did you use any rubber washers with the screws?
If you don't mind, would you share a photo of your installation?
Re antenna - yes, that is a good suggestion. From an aesthetics view I'm not too keen on the bonnet-side mount.
Sascha
