Results 1 to 10 of 20
Thread: Diesel additive - Puma 2.2
    Oct 2013
    Richmond, NSW
    Hi all
    For quite a few years now i have been using Chemtech diesel fuel additive in my 300Tdi & Td5 with no ill effects and I am assuming that its doing what it says on the label, as I have no real way of measuring this.
    But there is some discussion as to whether this (or similar products) are suitable for a 2.2 Puma. Does anyone have any real world experience with additives in a Puma 2.2 and have you had any measurable benefits or negative observations?
    Cheers - Simon
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Back down the hill.
    Assuming you mean the carbon cleaner, fuel additive. It definitely works, used to use it in a Mack E7 454, it saved an expensive rebuild.
    Just guessing, but it should be fine in any engine. It can be used in common rail engines.
    Nov 2018
    Hobart, Tasmania
    Quote Originally Posted by travelrover View Post
    Hi all
    Cheers - Simon
    Go for it!
    I use Fuel Doctor and/or Flashlube in my D4 3.0 diesel.
    Helps neutralise algae, breakdown moisture presence etc.
    Cleans wax buildup on injector nozzles.
    Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
    Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
    Oct 2013
    Richmond, NSW
    Yup, this stuff
    Travelrover
    Jan 2014
    Perth Western Australia
    For many years I have used products from Cost Effective Maintenance
    Daz
    Oct 2011
    Fremantle WA
    Quote Originally Posted by DazzaTD5 View Post
    Do you use it in customers cars as a matter of course?
    Oct 2013
    Richmond, NSW
    Thanks Dazza
    Have you experienced any problems with the Puma engines with this stuff?
    The image didn’t open but I found this?
    Travelrover
    Yass NSW
    +1 for cost effective maintenance products, I dont use the fuel conditioner but have used the engine flush on a few vehicles and am happy to recommend their products
    Regards,
    Tote
    Jan 2014
    i use...
    FTC Decarbonizer - good for injector rattle (defender tdci, lc 200), sticky turbo actuators (d3 / d4), vehicles with dpf issues.
    AW10 - engine oil additive (mostly as a preventative measure), use on customers vehicles (d3, d4, defenders), lt230 transfer cases (defenders).
    like all additives, its not the bee all and end all to issues but it can help.
    Daz
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    FTC Decarbonizer
    Since the DPF on my D3 met an untimely 4" cut off disc, I've been known to "boot it" from the odd traffic light at night so I can assess the opacity of the cloud in the headlights of the vehicle behind. I can absolutely say that 5 or 6 tanks into a bottle of FTC Decarbonizer I see a significant reduction in "hoon" exhaust smoke when making it work hard.
    I'm a sceptic at heart. I had a play with their "CRD Enhancer" a year or two ago and found that perhaps it marginally improved the injector balance figures on 2 of the 6, but made zero noticeable difference to noise or driveability on a day to day basis and the figures returned to where they were within a tank of ceasing use of the product.
    The FTC though really has gone from "**** me there's a massive cloud back there and might be a car in there somewhere" to "I can still see the car and its individual headlights through the mild mist. A significant difference.
    What that means on a long term basis, I have no idea. But on a $$ basis, I more than pay for the additive just by checking fuelwatch and picking cheaper diesel.
