Results 1 to 10 of 15
Thread: New Era twin headlight relays - are they still good today?
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Back in the day the duck's guts headlight relay of choice was the New Era Twin Headlight Relay the 12V 30A NLR-132. How does the NLR-132 stand up in today's usage? A quick search online finds that there are multiple headlight wiring 'kits' on eBay and Amazon that includes the female socket all wires and two headlight relays starting at around $26.00. These range in price from the cheaper 'no name' kits to branded kits that are around $76.00+ in value.
    Snowy - my 1993 Defender's headlight sockets are not serviceable anymore as they became brittle and subsequently broke. I have ordered a set of name-brand ceramic headlight sockets. This will be connected to wider diameter wire than the original fitment and hooked up to some New Era twin headlight relays that i already have available. They are previous purchases that have just been sitting waiting in their boxes to be put to good use.
    Am I just being old fashioned by staying with the tried and trusted New Era relays and not buying the readily available 'kits' for a cheaper price?
    Kind regards
    Lionel
    Funny you should mention them. I found a new old stock one of these in my garage recently. It was going to go into my ‘86 RRC some years ago. I sold it in 2002 after I got my P38A.
    Queensland
    Hi Lionel, I have been supplying the New Era relays with my headlight kits for over 20 years now and the failure rate is still very low and a lot better than so called headlight relays.
    One of the main advantages of these relays is the ability to easily clean them.
    Just hose them down and alls well.
    The biggest drawback with ready made headlight kits is that they use pathetically thin wiring.
    They use wiring that is capable of carrying the current required but they fail to allow for voltage drop.
    With any headlights, the higher the VOLTAGE at the globe, the brighter the light will be.
    So you need to consider both the type of relays and the size of the cable, to get the best results.
    Mar 2010
    Queensland
    12.97 MB
    Hello Drivesafe,
    Yes, back in the 1980s it was New Era relays and one size of cable more than "OMG, that is some really thick wire" as the general rule of thumb.
    Kind regards
    Lionel
    Apr 2011
    Dungowan
    Used them in rangie….6mm feed to relay…. 4mm to close headlight…… 5mm to far headlight…..14.1v at globes with engine running (was mid 11’s)…. Very noticeable improvement with std 55/60 globes in round hella housings
    '93 D1 V8 auto
    '93 D1 200Tdi 2-door, ARB's, MD transfer, sill tanks, winch, 2"lift.......
    '95 D1 V8 auto......gone
    '86 V8 RRC.....gone
    Sep 2013
    Darwin
    12.74 MB
    Interesting topic.
    I took my Discovery 1 for rego inspection - it passed - but with some criticism of brightness and alignment of lights. Hmmm. Later that evening put a line on the wall and set the vehicle back recommended distance - could not find a problem with brightness and alignment.
    Few weeks later took the 1990 Toyota Troopy for rego inspection - it passed - but with no comment on the pathetic lights, equivalent output of two birthday candles. I asked. Was told that Toyota comes from the factory with undersized wires (dim lights) and run both lights through one relay. Because its factory they don't fault them.
    Sep 2010
    The Hills.
    152.79 MB
    Glad you brought this up, Lionel. I'd forgotten these. I reckon one would be ideal for my OKA. It's sorta like a big Deefer, only less aerodynamic..... and the headlights are about as feeble as the sealed beams in a Prince of Darkness powered SII.
    Boy, there seem to be some knock-offs around.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by Tins View Post
    Hello Tins,
    Yes - lots of knock offs. The genuine New Era ones have 'made in Japan' written on the relay itself and New-Era ニューエラー written on the box.
    Kind regards
    Lionel
    Queensland
    Quote Originally Posted by Rick1970 View Post
    With defenders, because the battery is so far from the lights, I supply two lengths of 8B&S ( 7.9mm2 x 2 ) cable. One for the headlight circuit and one for the driving lights.
    NE Victoria
    32.83 MB
    Is there any reason why you wouldn't pick up power from the starter motor, the alternator or the under bonnet fuse box, which has a couple of unused slots, and is supplied from the starter motor as far as I can tell.
    Tony
