Results 1 to 6 of 6
Thread: Battery socket driver?
    Back down the hill.
    All my cordless tools are Makita, including a 330nm ½" drive impact driver. Makita don't seem to have a compact socket driver. I wouldn't mind a light duty unit, for occasional use. What are you fellows using and how do you rate it?
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    I have a set of socket (1/4 - 3/8 - 1/2) to 6mm hex adapters. I use those in either an impact driver or battery drill to twirl sockets when I'm away from my pneumatic ratchets.
    JDNSW's Avatar
    I have a 1/2 and 3/8 adapters with a 6mm hex shank that can be used in my small battery drill. Used it today for example spinning off and spinning up nuts when replacing shocks on the 110. Do the initial loosen and final tighten with hand tools and the same sockets. Even used it for the wheel nuts.
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    AEG sub-compact drill / driver combo set with 2 2Ah batteries, charger and another battery cost me about 250 last year at the green shed with the P/pass.These things are a joy to use.
    For cjust spinning nuts the driver is great. Just use quality hex to 1/4, 3/8, 1/2 square .drives. I use P&N.
    I have the bigger versions of these tools and they've done a heap of heavy work with no real issues.
    I have about 8 batteries, mostly over 6yo, only one that's a bit suss, most are 6Ah.
    The sub=compacts get used heaps more than the bigger ones now. A bit like chainsaws................. I have a big old stihl, but I use an 017 way more often.
    TTI own AEG and Milwaulke.................. and I think still owns half of TTI.
    cheers, DL
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by 350RRC View Post
    I'm doing some work at a fab shop at the moment and the owner has a huge set of these sub-compacts. Everything from right angle drill to die grinder. His are Milwaukee, but same same. I have to say they're an absolute revelation. Wish I could justify a set myself.
    Apr 2016
    First up, 40v(XGT) or 18v(LXT) is the major question re- Makita.
    Their 18v range is quite extensive, when compared to their 40v(which I'm into now).
    When you say 'socket' do you mean square drive? or do you mean any drive that can accommodate a square drive bit?
    And also how compact do you want/need it?(also, how much would you spend).
    For an all rounder tool, I reckon the hex drive impacts make for a better tool, compared to a square drive type, in that you can more easily adapt various bit ends more readily.
    That is, as an example, it's easier to find a drill bit, or posidrive for a hex tool than you can for a square drive(3/8ths or 1/2), where you'd need more adapters for a square drive. And with a hex to square drive adapter kit ... eg ...
    Hex to square adapter example ..
    throw your sockets, extensions or whatever square drive tool and job gets done. It's much harder with a compact to go from square to drills, screws, etc. Can be done, but harder to find the bits and adapters.
    Then you need to ask yourself how much power and variability do you need? If it's mainly for starting a fixture and running it in quickly or gently driving a screw into some fragile piece, then don't go for the maximum torque value, as it's min torque value is also higher.
    I'll assume that you have an 18v Makita battery setup already(going by your comment re the 1/2" impact) then for compactness, and all round flexibility(with other bits), something like the DTD172Z would be ideal.
    ps. If you don't already know of him: check out TOOLS & STUFF on youtube. He has a lot of reviews on Makita tools, and while they may be old in terms of most recent tech, still relevant.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
