Results 1 to 9 of 9
Thread: AC stopped working
    Aug 2010
    AC stopped working
    Hi all,
    Had my alternator replaced yesterday by an indie.
    Now today AC is no longer cold.
    Is there a chance they left something not plugged in?
    Cheers Rich
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Oct 2012
    Quote Originally Posted by ~Rich~ View Post
    Hi all,
    Cheers Rich
    Nothing relates other than the serp belt however get gas level checked before you panic.
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    If for whatever reason the compressor was unplugged you should see faults logged. The SDV6 has a clutch in addition to the displacement valve, so you have 2 devices that would leave unhappy fault codes if there was a physical issue. If you have a GAP it'd pay you to look at the system pressure. That's a pretty good indicator for go/no-go on the compressor and a telltale if there is insufficient gas.
    Aug 2010
    Screenshot_2024-08-28-14-46-34-529_com.gap.iidcontrol | Flickr
    Well the readings are unavailable 😔
    No faults though.
    Oct 2016
    Perth, AU
    No faults though.
    Sorry to ask a dumb question - was the engine running when you took the screenshot?
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Aug 2010
    Yes!
    Ignition on and engine running!
    Aug 2010
    Sorted
    Ok
    Well it was a coincidence!
    AC was only about 50% charge and that stopped it working.
    The IIDTool didn't show the HVAC readings because it was connected using a short extension cable.
    When direct it shows.
    Screenshot_2024-08-30-05-25-49-252_com.gap.iidcontrol | Flickr
    Oct 2012
    It’s designed to severely mess with your brain those coincidences.
    Supporter
    Mar 2018
    Perth (near Malaga)
    Ok
    The HVAC is on the medium speed CAN bus. Perhaps your cable isn't a complete passthrough.
