Thread: L320 RRS - Angle Eyes
    I have to pull the lens off my RRS headlamp housings and replace them with new ones. While doing this I thought I might put Angle Eye Light Rings around the hi and low beam lights to act as DRLs.
    So I can buy the rings in advance, does anyone know what diameter rings are required? There will be two smaller diameters and two slightly larger diameters.
    NSW SW Slopes
    Angle rings are as useless as the rings of LEDs around my MY12 L322's headlights for DRLs as they don't catch a driver's attention from a distance unless it's so dark that headlights should be on.
    I've configured my headlights as DRLs in the CCF (Scandanavian IIRC) so that they are always on while the ignition is on except if parkers is selected at the switch. Headlights aren't good DRLs but are far better than parkers or Angle rings.
    Angle? I thought they were referred to as Angel Eyes. Which is correct?
    St Helena,Melbourne
    1.13 MB
    Depends on your viewing angle Ron , but yes angel eyes or halo's. I assume they would be the same size as what some guys fit to D3 lights, try looking on the disco3 forum.
    I was thinking of doing it as well just to update the front a bit along with the de-tango mod.
    Check this - DISCO4.COM - View topic - Discovery 3 Xenon LED DRL halo conversion
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW SW Slopes
    Typo - meant Angel
