Results 1 to 10 of 26
Thread: Discovery 2 Crank no start, only 6c permanent voltage supply dtc
    Sep 2024
    South Africa
    Hello, hoping someone can assist me in the right direction please, mechanic also lost the original crank sensor, does it use a spacer on the manual v8 4.0?
    ALso on the crank sensor wiring I have a ground and both other wires supply 2.4 vault, should the one not supply 12v 0r 5 and the other a signal wire?
    Thank you in advance.
    Sep 2010
    The Hills.
    152.79 MB
    Simple things first. Have you checked the crash switch? Inertia switch on the firewall, might need resetting.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2024
    South Africa
    Hello and thank you for the prompt reply and yes i have pressed it multiple times lol.
    Jul 2014
    west of Transylvania
    Quote Originally Posted by jassoyer View Post
    Hi there is not supposed to be any supply for the crank sensor, that 2.4V might be capacitive if it's not an ECU fault, i attach you the description rather than explaining myself but you need a compatible scantool to diagnose this and watch rpm which must be above 250 while cranking for te engine to start and if it was the sensor a specific fault code should be present
    Sep 2024
    South Africa
    Thank you very much, that is the part confusing me.... only have a single fault code -6c permanent volage.... drive cycle A. REason I am investigating the crank sensor and voltages/signal to each wire on the cps is to establish if the cps is working as I see no rpm on tacho or Autel elite or Launch x431 V+.
    Jul 2014
    only have a single fault code -6c permanent volage.....
    Which P code is associated to that?
    Sep 2024
    South Africa
    Will get oem tool to test and confirm as I can only get the 6c code with my two high end tools.
    Sep 2024
    South Africa
    Greetings, sorry for the delay, error code is p109, changed the crank sensor as a new replacement arrived, still now no injector pulse or spark, but zero fault codes now to work off..... No rpm still.
    Get a landie they said.... lol gonna be something sillyI feel, not clued up enough yet with landies to be honest... Any further suggestions would be appreciated?
    Jul 2014
    The OBD code should have 4 digits after the P so that 109 is not clear enough, if it was 0109 it was about MAP. As long as no rpm reading the sparks and injectors are inhibited by the ECU... swap the two big relays at the bottom of the interior fusebox(R3-R4) see if it helps and if not remove the lower one R4, bridge the perpendicular cavities(where the contact goes) with a wire and see if you get spark then...if not measure if you get 12V across the parallel cavities(where the coil goes) when you turn ignition on...allso check fuse F14
    if no joy with the above check fuse F13 engine ebay and swap relays R9(main) with R8 there
    Sep 2024
    South Africa
    Hello again, got a chance again to have a look at her, checked all relays and fuses and they appear okay, tested with power probe, putt he wire bridge to relay 4 like you suggested |-- ports of the relay, still no spark, not sure of which = ones you refer to as I o not get 12v on the two on the same relay 4. Just checking I am understanding your info correctly? Thank you again, really appreciate your help.
