Results 1 to 10 of 12
Thread: Anderson plugs ain’t Anderson plugs, Sol!
    I have a number of 50A “Anderson” plugs for different auto/camping needs.
    Some of the plugs are quite difficult to separate, in fact, they require a screwdriver inserted into the gap between the plugs to force them apart.
    I tried just the plastic housings without the terminals and it made no difference, they are still very difficult to separate.
    Aha, thought I. It must be dimensional differences between genuine Anderson and Chinese knock-offs.
    I was wrong (partly). Yes, the knock-offs are hard to part from the genuine Anderson but perfectly OK when used with their own matching brand and other non-Anderson brands. But the genuine Anderson plugs are almost impossible to separate. I think I’ll need to buy the T-handle attachments for the Andersons or just throw them away and use the knock-offs.
    Mar 2018
    Perth (near Malaga)
    My experience with Anderson and knock offs hasn't been great. I ended up replacing all of the various knock offs with Anderson shells.
    Anderson also do high force and low force contacts. The high force certainly contribute significantly to the connect/disconnect friction.
    99.87 MB
    My very basic experiences are to keep the colours the same also, eg the light grey ones and the red ones look exactly the same, but they dont mix.
    Grey goes with grey and red goes with red.
    Slunnie
    Mar 2018
    Perth (near Malaga)
    Indeed. Only Grey and Black use the same keying. The remainder are colour for colour only. The great thing about the Anderson connector though is if you do have the wrong colour you can simply pop the contacts out and swap the shell.
    Queensland
    I have only ever used genuine Anderson plugs.
    I don't how many times customers have rolled up with a problem with their "Anderson" plugs and they have been knock-offs.
    Also note, genuine 50 amp Anderson Connectors are rated at a continuous load of 95 amps, while many of the knock-offs would be lucky to carry 50 amps.
    And it is not just the plugs but the terminal size.
    I have seen knock-offs with terminals as much as 1/3 smaller size ( width ) than a genuine Anderson plug.
    Today, genuine Anderson plugs are as cheap as many of the knock-offs.
    Jul 2009
    Hobart
    Hi,
    A bit of strap and 2 screws works for me.
    Sep 2010
    The Hills.
    152.79 MB
    Hmm.... Maybe a seat belt?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Mar 2018
    Perth (near Malaga)
    Thats why my SB50 wants to become when it grows up.
    Sep 2010
    The Hills.
    152.79 MB
    It's an SB350, and they are a PITA to disconnect. My OKA had them for a front or rear demountable winch. Sounds like a great idea but it isn't.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Mar 2012
    Armstrong Creek, Qld
    My local auto electrician showed me the difference between genuine and fake, a few years ago. Quite noticeable, when you know what to look for. One plug, that I'd purchased from an auto store, had a flaw in the contact's 'Seating' bit.
    'sit bonum tempora volvunt'
