Results 1 to 10 of 35
Thread: TDV6 oil pumps
    Jun 2020
    Eltham
    TDV6 oil pumps
    Just about to start a major service on my 2005 D3. 555400km
    One of the major items being changed is the engine oil pump. Watching Christian and Vera on LRTime on youtube , he does a very good comparison of oil pumps.
    Im wondering if the pump from the SZ territories is the same as the LR one. Are they identical regarding rotor capacity?
    LRTime compares the genuine LR ones and aftermarket ones. Genuine pump turns out to be the best obviously. He also says the Peugeot / Citroen pump is the same as the LR pump, just with a different part number and half the price too.
    So is the pump from ford the same as the LR item?
    thanks in advance
    Andy
    The LR pump is the Ford Pump and Ford charge about the 1/3 of the LR price.
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Andyducati View Post
    thanks in advance
    Andy
    Yes it is the same, i got my pump from a Ford dealer when i did mine, i see you are close to me so if you need a hand send me a pm.
    I also have the locking pin set for doing the belts which you will need, ive a done couple now.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2020
    Eltham
    That would be a great help. many thanks for the offer, although you may back out quickly when I list the extent of the jobs I'm doing.
    Im doing the head gaskets on a half million KM discovery, plus full head rebuild, oil pump, timing belts, full fluid change. Plus whilst I'm in there I'm completely removing the full EGR system and gutting the CAT.
    But if you still want to stick around then
    Apart from that it runs like a dream.
    Oct 2012
    That’s a great achievement if it’s the original donk. Pretty sure #1 km leader. Have you owned it a long time?
    Jun 2020
    Eltham
    Quote Originally Posted by PerthDisco View Post
    I believe its original. 555400km with a mostly full service history.
    Only had it 3 weeks or so. Just got through a roadworthy with very few fixes to get it through.
    NSW SW Slopes
    Have you considered replacing the bearings? It would be a shame for the bottom end to let go after such a top-end overhaul.
    Oct 2012
    TDV6 oil pumps
    Sure would be interesting to see the colour of them.
    It might be Oldsalts (?) car that had high kms and contributed regularly here.
    Jun 2020
    Eltham
    I don't think I will go that far on this engine at this time. I am going to get another engine at some point and rebuild that ready for if/when this one decides to leave the farm!!
    Doing the head gaskets on this one because they need doing now.
    St Helena,Melbourne
    1.13 MB
    Yep i'm a glutton for punishment, i've used Eltham cylinder heads recently and they did a good job on my wifes X-trail head.
    1974 VW Kombi bus
