Thread: Lead Acid and Lithium Dual battery setup for D3s
    Queensland
    A lot of care must be used when selecting a lithium battery as an auxiliary battery.
    SPECIAL NOTE, lithium batteries should NEVER be used as a cranking battery.
    The primary difference between charging a lead acid battery and a lithium battery is that a lead acid battery requires three stages of charging, Bulk, Absorption and a Float charge.
    Whereas Lithium Batteries require two stages of charge, Bulk and Absorption, and once charged, the charging source must turned off.
    ALSO NOTE it is very rare for a Lithium battery’s BMS to act as a current limiter during charging, In other words, the lithium battery’s BMS does not shut down the battery once it is fully charged.
    Many Lithium Battery BMS will shut the battery down if there is a high current DISCHARGE, this has nothing to do with charging.
    The above info relates to charging with a DC/DC device, Solar Regulator and a 240vac Battery Charger, it has little to do with charging from an alternator.
    ALTERNATOR CHARGING OF LITHIUM BATTERIES.
    There are a number of specific requirements when charging lithium batteries directly from an alternator.
    First and foremost, when selecting a lithium battery for charging directly from an alternator, with a Discovery 2 or 3, the battery MUST HAVE a CONTINUOUS CHARGE CURRENT rate of at least 100 amps.
    NOTE this is NOT the MAXIMUM charge current makes on a lithium battery, as this is something a lithium battery can only tolerate for a very short time of a few seconds to a few minutes.
    If you have discharged a lithium battery to a low state and you then drive for a few hours, the battery could be receiving a charge current as high as 100 amps for quite some time.
    Note, this does not apply to a Discovery 4 or any vehicle with a SMART alternator function.
    I have tested charging a Lithium battery with a 140 amp alternator and with a 100Ah lithium battery mounted in the rear of the vehicle and Twin 6B&S ( 13.5x2 ) cabling connecting the lithium battery, via a DT90 isolator, to the cranking battery.
    While I monitored the currents in both directions ( Charging and discharging ) I would periodically blow a 50 amp fuse but an 80 amp fuse allowed 70+ amps of continuous charging and up to 140 amp discharging while starting the motor.
    How fuses work is for another time.
    I could change the operation of the alternator in the vehicle I used, from a SMART alternator function, similar to a D4, to a Variable Voltage alternator function, similar to how a D3 alternator works.
    My tests were two fold. They were to see how my SC90 and DT90 isolators worked with a lithium axiality battery and how well a lithium battery could be charged with an alternator.
    When charging a lithium battery from an alternator, you do not have to worry about shutting the charging off once the lithium battery is fully charged as this will happen every time you turn your motor off.
    Constant charging of a fully charged lithium battery from an alternator would only be a problem if you were to regularly drive for 10 to 15 hours straight. Not likely to happen.
    My findings were that my isolators worked fine with a lead acid cranking battery and a lithium auxiliary battery but I got some interesting results relating to using a Lithium Auxiliary battery.
    First off, because lithium batteries have a higher and constant rested voltage ( around 13.2v -13.4v ) my isolators would remain on, regardless of whether they were set to Ignition mode or Shared mode.
    So when I turned the motor off, with the lithium auxiliary battery sitting at 13.3v, and the lead acid cranking battery sitting anywhere from about 12.3v to 12.7v, the lithium would slowly discharge back into the cranking battery.
    I used this setup for a little over two years.
    The alternator operating in Variable Voltage mode, would really get much over 14.0v and regularly settled down to 13.5v, while driving.
    This still allowed the lithium battery to be fully recharged ( 95% or higher ) even after short drives.
    NOTE, the cranking battery was on its last legs and beginning to fail to start the motor, through age, when I first put the lithium battery in.
    As I stated, the lithium battery was used in this setup for a little over two years, but with in a few days of installing the lithium auxiliary battery, the cranking battery’s starting performance improved dramatically.
    After having the lithium auxiliary battery in for two years, I decided to remove it to carry out a fully monitored bench discharge test.
    The lithium battery still had a 100% capacity.
    But the surprising thing was that the “STUFFED” cranking battery lasted another 6 months and I only replaced it when my BM2 Bluetooth Battery Monitor warned me that the cranking battery voltage went too low when starting the motor.
    Now when camping, with two lead acid batteries, the cranking battery and the auxiliary battery, while camping, your fridge, camp lighting, phone and computer charging, etc, current would be shared and come from both batteries.
    With a lead acid cranking battery and a lithium auxiliary battery, all the power would initially be coming from the lithium battery even though the two batteries are still connected.
    Only if the lithium battery was discharged down to about 15 to10% SoC, would power start coming from the cranking battery.
    In this situation, the DT90 isolator still protected the cranking battery from being over discharged and the DT90 would completely shut down before the Lithium Battery’s BMS shut the Lithium battery down.
    When you went for a drive, even with both batteries discharged to their lowest allowed level, both batteries would be back over 95% in about 90 minutes.
    If you decide to use a lithium battery as an auxiliary battery, you could use two lithium batteries with a continuous charge current of 50 amps, as long as they are wired in PARALLEL.
    St Helena,Melbourne
    1.13 MB
    Tim, will the SC80 still behave the same as per above ? My AGM aux is still going after 6 1/2 years but when it does die i want to switch to a lithium for increased capacity.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Tim,
    I'm about to fit a lithium in the L322 (M62) but charging through a 25A DC-DC charger. Do I need to isolate the DC-DC charger with my SC-80?
    I was going to directly (via a 40A circuit breaker) connect the DC-DC charger to the terminal in the rear fuse box area (the one you used for your dual battery system - your pic below) but without the SC-80 in circuit. I had my previous dual battery system fed from that terminal.
    Queensland
    Yep, will work fine in a D3.
    Queensland
    Tim,
    Hi Ron you will need to use a DC/DC device with an IGNITION activated setup and then you will need to source an Ignition circuit in the rear fuse panel to turn the DC/DC device on and off with your motor.
    BUT, why are you going to a lithium battery?
    You are going to loose a heap of advantages that a Lead Acid battery setup offers, like automatically keeping your cranking battery topped up and the shared load, which means you need to replace the 55Ah Optima with at least a 120Ah lithium to have the same capacity.
    Thanks Tim.
    I never had an Optima (except for a short while in the RRC), I had 2 x 45Ah deep cycle AGMs in parallel (that what fitted in the L322 space) but they died so I went for a replacement in the form of a 100Ah lithium. It won't fit in that space under the electrical panel but it's light enough to remove easily when it's not required. (I'm sort of reluctant to leave a lithium permanently in the car.)
    The 2 x 45Ah batteries were never that successful. One battery lost a lot of capacity over time.
    A friend gave me (after me purchasing the lithium), a 90Ah deep cycle AGM but it won't fit into the well under the panel (it will sort of fit but it's too tall). It's so heavy I struggle to lift it.
    My old setup didn't use the SC80, I bought it a long time after setting my system up but never got around to fitting it. Mine had a PowerTech MB-3688 programmable dual battery controller.
    The DC-DC charger has an ignition enable connection. I have an ignition source in the back as it was required for my MB-3688.
    Queensland
    Hi Ron and all the best with your setup, but I would like to clear one point up, for the benefit of other.
    When installing one of the Traxide systems, do NOT use a Deep Cycle battery, use a Cranking Battery for the auxiliary battery.
    Main reason being is that cranking batteries, by their very design, will charge much faster than a deep cycle battery.
    This is important when charging from high current capacity alternators as found in new Land Rovers.
    While this point is irrelevant in an L322, because the battery is in the boot, but cranking batteries are specifically designed to better tolerate under bonnet heat, thus giving them a better potential life span than a deep cycle battery.
    Although not as important, but cranking batteries can be safely used in deep cycle applications but deep cycle batteries do not like being used to start motors.
