the gold or silver coloured metal assembly that the indicator stalk, head light stalk and wiper stalk assembly is attached to is what the bottom column surround screws to underneath.
the whole complete stalk assembly (indicators, wipers, headlights including the metal bracket) is attached to the round steering column with the plastic ring with a screw in it, this ring is part of the indicator assembly. the top of the ring has a space to allow for the screw to tighten up the ring, the space aligns with a raised section on the round column.
the slot and the raised section are either not aligned or more likely, if you over tighten the ring just a fraction it snaps and allows the whole assembly to float or rotate to any spot.
also the screws on the bottom plastic surround have pulled through the plastic or some other bodged glued repair work in its past.
I always remove the steering wheel when doing anything in the dash and the surrounding plastic as the plastic on Defenders is poor quality and hard to get right.
