Here's one i did last week🤪
When doing a belt. You fit two timing pins before removing the old timing belt.
One goes in the drain hole in the bottom of the bellhousing, this goes into a slot in the flywheel, this locks the motor at TDC on cylinder 1.
The other goes in the fuel pump to lock it.
Then there is a mark on the camshaft pulley that aligns with a thing in the housing.
In the attached photo the bottom arrow is pointing to the harmonic balancer keyway, this needs to be pointing up.
The big pulley top left, the arrow is pointing to were the locking pin goes in the fuel pump.
The big pulley, top right, the arrow is pointing to the mark and what it aligns with. It looks like it's out due to the angle of the photo, but it's aligned.
These are the timing pins I have, they are not genuine Land Rover ones, I can't remember were I got them, but one of the Land Rover suppliers.
The black one goes in the bellhousing, the silver one goes in the fuel pump, yes it is a cut off bolt.
Can you post a photo of the whole Zeus gear set? I assume there will be timing mark on the camshaft gear, similar to what is on the belt pulley.
It sounds like you don't have a workshop manual, you can buy an electronic copy for not much in the shop section at the top of any AULRO forum page.
Hope this helps
Tony
