Results 1 to 10 of 28
Thread: Stuck steering wheel
    Sep 2017
    Anyone got any tips on pulling the steering wheel off my 80"?
    I've tried various ways of pulling the boss against the inner splined shaft but it's pretty well stuck.
    Need the wheel off so I can remove the bulkhead
    Oct 2007
    Wantabadgery, N.S.W.
    I used a gear puller with lots of ancillary bits and pieces to avoid damage to the hub of the steering wheel. Mine was well and truely stuck.
    Good luck with it
    Don.
    Jul 2009
    S.E.Qld
    Years ago I removed an 8o" firewall with the steering box and steering wheel still bolted to it. I leant (leaned ?) it against a wall, it fell over and smashed the Bakelite steering wheel centre horn push and hi-lo light switch. Lesson learnt.
    .W.
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    About all I can suggest is to make a puller if you don't have or able to get a suitable one.
    This could be made from a substantial steel yoke that pulls on the hub either between the housing and the hub (not sure there is enough space) or bevelled and padded to fit as low as possible on the hub. Two HT bolts at least 10mm to a very substantial cross bar, with the three holes, the centre one tapped to allow a 12mm bolt as the thrust element. This needs to have a suitable pad to sit on the top of the column.
    Use an electric heat gun to heat the hub as hot as you can without damaging the paint, and freely apply penetrating oil.
    A very narrow angle wedge could be driven into the slot to expand the spline, but be very careful,it is easy to damage the hub. (been there)
    Best of luck!
    Jul 2009
    S.E.Qld
    The underside of the boss of the original 80" wheels, the ones without the tapped holes for the horn contact found on SIIs, are more easily damaged by hitting them from below. Don't be tempted.
    .W.
    Sep 2010
    The Hills.
    152.79 MB
    Only thing I can add is to leave the nut on at least a few threads for when it lets go.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jul 2009
    S.E.Qld
    Left: SI, Right: Later.
    .W.
    Jul 2009
    S.E.Qld
    Quote Originally Posted by Tins View Post
    Why, how ? The bolt has to be removed before the wheel can be pulled off.
    .W.
    Sep 2017
    Best of luck!
    Thanks for the responses.
    I have tried all of the above. Used a large bearing separator to grip around the splined shaft under the yoke (flat side under yoke). Then used two spring compressors to reach up to a t-piece where the horn button would be. This T-piece pushes down on a tube that just fits down the centre hole and bears on the top of the internal shaft (I'll take a photo tonight).
    Torqued the Ba$tard up and even applied a bit of heat to the yoke. Plenty of penetrating oil. Nothing.
    I took the steering box apart but of course I can't withdraw the internal shaft without removing the top bearing which needs the steering wheel off.
    Guess I just have to keep trying.
    Jul 2009
    S.E.Qld
    Best of luck!
    Th
    The steering column is hollow and not really suitable for a puller. This is what we're dealing with.
    The problem with using a 'narrow angle' wedge is that it will hit and damage the splines before it starts spreading.
    .W.
