Results 1 to 6 of 6
Thread: Class Action related to L462 - Discovery 5
    Jun 2010
    Australia
    ‘Evening all
    Looking for information on how to update my car’s maps, I came across the following this evening:
    Jaguar Land Rover Class Action | Maurice Blackburn
    Make of it what you will.
    Mark
    What year is your car?
    My 2019, to update maps - done monthly - I just download a file from Land Rover and an ap on my computer writes it to a USB stick which then uploads it to the car.
    Early models used an SD card from memory.
    Numb Thumbs
    Fuji White 2019 SE Sd6
    Interesting, and probably should be given a wider audience on the forum since it applies to all? diesel LR vehicles (not just the Discovery 5) manufactured in recent years.
    Make/Model
    Vehicle Code
    Model Year
    Land Rover Defender L663 2020-2024
    Land Rover Discovery L462 2017-2024
    Land Rover Discovery Sport L550 2017-2022
    Range Rover L405 2017-2022
    L460 2022-2024
    Range Rover Evoque L538 2016-2019
    L551 2020-2022
    Range Rover Sport L494 2017-2022
    L461 2023-2024
    Range Rover Velar L560 2018-2024
    The website says this is a consolidation of 2 separate class actions against JRA over the same matter. So somebody out there is unhappy. While I recall posts on the forum about the problem I don't recall anybody speaking of legal action.
    What is the Jaguar Land Rover class action about?
    The Jaguar Land Rover class action has been brought on behalf of group members (see table below) who acquired the relevant models of diesel Land Rover, Range Rover and Jaguar motor vehicles, other than by way of auction or for the purpose of re-supply, between 1 July 2015 and 8 August 2024 in Australia.
    The class action relates to affected vehicles that contain an exhaust filter system, including a DPF, designed to reduce emissions in order to meet Euro 6 emissions standards. Broadly speaking, the action alleges that the DPF system is defective and the affected vehicles have a propensity to experience various problems including engine oil dilution and contamination, degradation of engine parts and the DPF system, blockage in various parts of the DPF system, diminished vehicle performance, entering into limp-mode without warning and greater servicing requirements.
    The class action alleges that Jaguar Land Rover failed to comply with the guarantee of acceptable quality under the Australia Consumer Law and engaged in misleading and deceptive conduct.
    The class action seeks to recover compensation for loss and damage on behalf of consumers with vehicles affected by the DPF issues. It does not seek to claim for loss or damage which is not related to the DPF system.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Jul 2024
    Well, I can se why they are unhappy. The ERG/DPF system on these is questionable. Just bought a 2018 D5 and dealer had to replace DPF, ERG Valve, ERG filter mesh, and exhaust flag actuator. Car was having constant amber engine light and EGR codes. Once one issue happens it contaminates the entire system.
    Its pretty crappy when by law these systems are required but the end user fits the bill for the repair and maintenance. LR shop contacts told the indy fixing my car that they dont even bother with the EGR valve mesh filter anymore cause they just clog up. Mine was fully clogged.
    Only part not replaced was the ERG cooler.
    Glade it happened under warrenty.
    Quote Originally Posted by Alex_Rogan View Post
    Well, I can se why they are unhappy...
    Looks like they are unhappy in the UK also, class action being raised against JLR there by legal firm Milburg-London.
    Jaguar Land Rover You Owe Us
    Interesting see where it all goes... if it goes anywhere, that is.
    1984 RRC, in hell
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Ferret View Post
    This one made it through the High Court.
    Toyota Class Action
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
