Results 1 to 4 of 4
Thread: Central Locking
    Oct 2024
    Parramatta
    Central Locking
    I’m new to land rovers, I have just purchased a 2014 Discovery 4. The front passenger door will not lock or unlock via the Key (remote) or via the drivers door. However if you use the lock on the front passenger door it will unlock and lock the other doors.
    Is this a new actuator or something else?
    I’ve also noticed that on occasions all the windows lower when you unlock the car? I had a ford that done this when the battery was going flat.
    regards
    Wato
    Mar 2016
    Quote Originally Posted by Wato77 View Post
    regards
    Wato
    Yes it’s a faulty actuator.
    Windows all down is a function on the remote when you hold the unlock button for a few seconds.
    2007 Audi RS4 (B7)
    Mar 2012
    melbourne
    A low or flat battery will cause a multitude of problems and faults in any modern car
    ensure the battery is in good condition and terminals have good connections before anything else
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Sep 2014
    Baldivis WA
    You may have to remove teach the car what the window limits are for full up and down, common when battery starts to fail. And it's a function on the fob as stated.
