Results 1 to 10 of 11
Thread: Adwest 3 bolt steering box leak
    Sep 2010
    daylesford, 'sunny' central highlands of victoria
    Hoping for some advice .
    I am helping a mate who can't crawl around under his 86 County.
    It has a 3 bolt steering box with a leak from the sector shaft seal.
    I eventually got the seals out after the usual shenanigans we all go through ,unless of course we are pros.
    Question is the seals in the kit (suitable for a 3 or 4 bolt box) don't "fill" the space between the circlip and the end of the space around the shaft where it tapers in and ends. the seals taken out stack up and measure approx 11 mm where as the replacements stack up and measure about 9 mm
    the old seals under the circlip had the usual rubber encased washer then a seal with a spring inside
    the new seals are the rubber encased washer and a soft blue seal
    Hitch
    hitch
    96 130 300 tdi twin cab ex RFS
    96 300 tdi disco ( project / donor to keep 130 going ! )
    06 110 td5 wagon gone (not missed)
    94 110 200 tdi wagon gone (sorely missed)
    Avoca Beach
    IMHO the real problem is not the seal but play in the bottom bearing of the sector shaft.
    The bearing is like an engine bearing but has a split and when worn lets high pressure fluid past it.
    This happens especially when cold .
    When I lived in Riyadh, there were 4 Range Rovers next to each other and every morning there would be 4 oil trails down the road.
    The bearing has to be reamed to sector shaft size with a parallel reamer. I did it in many hours with a brake hone and the new seal never leaked again.
    Maybe there are other remedies these days but I think not.
    Regards PhilipA
    After 91? the sector shaft bearing was changed to a roller bearing.
    Sep 2010
    Not exactly what I was hoping to hear !
    hitch
    Sep 2010
    I was thinking it would not matter because the high pressure inside would force the seal outwards against the inside surface of the rubber encased washer and hey presto the seal seals !
    Too simple to hope for I suppose .
    Hitch
    hitch
    Avoca Beach
    No the problem is that the sector shaft can move sideways when the bearing is worn so one side of the seal is compressed and the other not.
    That's my theory anyway. And about 40 to 20 years ago this was the accepted explanation. And it fixed my leak.
    That was on an 81RRC . To prevent on my later 91 I bought a new box as Adwest had a special at $700!!!!
    Regards PhilipA
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    Regards PhilipA
    I can remember Dougal from NZ solving this problem by using a bronze bush that was possibly off the shelf.
    It'd be a big search to find the post.
    edit............ Craddocks in the UK sell the bush............. I assume it's for a 3 bolt.
    DL
    Jun 2013
    Universe A
    350RRC's Avatar
    Quote Originally Posted by shack View Post
    That's the one, well done!
    There may be a later thread where he has the sector shaft bearing surface reground and gets bushes reamed to suit............again not expensive.
    This fine vid is a reco'd 4 bolt with a different problem, but the shaft has been reground in the past:
    https://www.youtube.com/watch?v=xXQIsfBBhkk
    The WSM I have shows two of these bronze bushes on the sector shaft in the bottom of the box, 3 & 4 bolt the same.
    A new 3 bolt box is $3.5k in the US.
    cheers, David L
    Avoca Beach
    Yes, AFAIR (from 40 years ago) you do not have to do the first steps to get the sector shaft out. AFAIR just take of the top cover and drive it out. Once it is out you drive the bush/bearing out from the top.
    The tedious task is sizing the bush to the sector shaft.
    I was in Riyadh so couldn't find parallel reams so used a brake hone for about 6hours or so, stopping to test the fit at intervals.
    Parallel reams are not really that common so good luck. if not brake cylinder hones are more easily available, but a PITA But are probably necessary for a good finish after reaming.
    Regards PhilipA
    St Helena,Melbourne
    1.13 MB
    Must be 25-30 years since I rebuilt the 3 bolt box iny old 81 rec, was painful reaming the new bushes especially the one in the lid.
    At the time there was a conversion to put a roller bearing in the lid instead of a bush.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
