Results 1 to 6 of 6
Thread: Connector from hell
    Nov 2024
    Connector from hell
    G'day all,
    My apologies if this have been asked 1000 times before, I am new to the LR3 family.
    Hoping for some helpful advice regarding a coolant leak.
    We have a Coolant hose connector broken on our 2006 LR3, I'm not sure if this hose is for the rear AC or something else as it goes through the firewall.
    What is the easiest way to remove these stupid connectors? (see attached pic)
    Or is it going to be easier to cut the connector out and replace the hose clamps with something more user friendly?
    I have a T connector to replace the broken OEM part.
    Looking forward to getting this fixed.
    Thanks heaps
    Andrew
    Apr 2016
    assuming that you're referring to the black connector with the teal coloured tab? if so, then search for 'fuel line pliers' ... pliers with ends that are hooked inwards. you have to press the tabs inwards, whilst jigging on the connector.
    if you're referring to the hose spring clips instead, then do a search for 'spring clip tool'. there are variations of these and you have to be careful if you choose to have only one type.
    Hopefully you can see the same search that I got: for the fuel line pliers, the one that works best is the curved in pliers with the blue handle. I have a couple of types, but the one i use most is that blue handled one, as it gets into the tighter spaces better.
    For the hose spring clips(top tip! ... chuck them out as you remove them and replace proper worm drive clamps! ... but that's just my opinion) .. anyhow, I find that the best overall tool to have is the type that has the long bendy wire. In the search link see the one that has three types pictured on TEMU. Good to have multiple types for ease of use, but if you only had to have one type, get the bendy one. Again related to confined spaces.
    I try to buy as much as I can from local shops, where possible, but if not, I use ebay(easy).
    Sounds like you're new to LR, and you appear to be willing to fix yourself. Good! prepare to get a lot of dedicated tools to work on your LR. I did notice your welcome thread ... so welcome!
    Don't know what vehicle brand you have come from, but you say "new to LR" ... so assuming from some other make .. if so ... you need to subscribe to LR TIME on youtube. funny to watch and interesting content and relevant for your vehicle.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    St Helena,Melbourne
    1.13 MB
    You can't use a hose clamp as the fitting is shaped for the push fit connector, but you can buy replacement hoses and connectors .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW SW Slopes
    I have a swivel head spring clip tool that makes removing and refitting the clips dead easy, including when in tight places and is much easier to use than having to tighten screw clamps.
    Quote Originally Posted by Tufty Capybara View Post
    G'day all,
    Only Americans call the Disco 3 an LR3.
    Nov 2024
    Thank you for the information. It's always a great day buying new tools
    Coming from a 84 FJ60 its kind of unusual having parts that are not held together with zip ties or SOS tape.
    once again thanks for the help.
    Andrew
