Thread: Discovery 3 V8 Smoke Screen - diagnosis
    Apr 2012
    Coolum
    Driving to Brissie today
    Awesome spectacle of Billows of smoke pouring from the back of the Disco 380,000 klms .
    Pulled over called for help RACQ to home
    Car seems to run OK - cleared some fault codes suggesting rich in some pot and lean in others.. no other sensors saying anything - but global warming contributions are obvious.
    anyone care to suggest most likely diagnosis.
    Seems terminal to me - Car is in great nick other than that and always well maintained - but not worth doing a new donkey installation
    Steve
    D3 2005 4.4 V8 HSE java Black.Alpine Roof,Alpaca Leather 7seat,LRSat Nav,E diff,Bi Xenon.Hi-Ice et.voice control.Bluetooth Phone.Kaymar rearbar.Roofrails and Racks.18rims.Traxide Dual Battery towpoint Anderson plug. Xenon 4300k Hbeam.10wled450lightbar.
    Mar 2012
    melbourne
    I would run a strong mix of fuel doctor though it and see what it does, great stuff for cleaning out the fuel system
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Sep 2014
    Baldivis WA
    D3 V8, petrol, i assume? Blue Smoke = oil, so my bet would be rings or valve guide seals, or dome way that oil is getting into the combustion areas.
    Blue smoke on the diesels usually means the oil drain from the turbo is blocked, forcing oil into the exhaust.
    Apr 2012
    Coolum
    Yes D3 V8 and oil the most likely culprit.
    Was going to scrap the car but its a great car and the rest is well maintained so I am looking to get a second hand motor and getting someone to drop it in ..
    then use it for camping - sleep inside and beachwork.
    Replacement L405 V8 Diesel on the way.
    Steve
    Oct 2016
    Perth, AU
    Quote Originally Posted by coolum View Post
    Interested to hear how this goes. I watched a youtube vid of some lads putting a diesel engine into a petrol chassis Land Cruiser, which ended up being way more complicated than they expected. Wonder if the same issues come up in the disco...
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
