Concentrate on the code you highlighted. The remainder 'U' codes are all communication related and could well be collateral damage. Often when dropping into a limp or failsafe mode an ECU will stop or slow communications on the bus causing faults in all downstream modules.
I have no real info on the CPS on Petrol engines other than the service manual. On the V8 it can be replaced from under the car. On the V6 apparently the exhaust system has to be removed first.
P0335 is a bit of a rash all over the internet, but there's not a lot of landrover specific hits.
