Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: What did you do to your L663 today?
    Jul 2003
    A popular topic in other sections so I thought it might be here as well.
    Mahn England
    Ex 300Tdi Disco:
    Jul 2003
    Compost in the bonnet hinge wells!
    The bonnet hinge wells in the SMEG fill up with leaves and these turn into compost.
    It's an awkward place to clean out.
    I've tried vacuuming but that doesn't work so today I got the compressor going with a blower attachment and a length of wire and eventually cleaned both sides out. It took a good half hour!
    In order to help keep "shrubbery" out I've inserted one strip of packing foam either side of the hinge bits. This closes the gap and allows the hinge components to move up and down. The space at the end where the water drains is left open.
    packing foam
    inserted
    Hopefully this will keep the leaves at bay.
    Mahn England
    Ex 300Tdi Disco:
    Melbourne, AU
    I fitted a Redarc brake controller. Still need to finalise the switch position.
    I hate working under the dash doing vehicle yoga. As others have noted the plug is difficult to seat in the built in socket.
    I sanded the plug a little before attempting but found that unclipping the socket then using a pair of multigrips made the click connection.
    Previously have installed a TJM single compressor on a TLR bracket in the engine bay. Nice neat solution and use of space.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Sep 2014
    Baldivis WA
    JLR fitted my Redarc. very professional job, down by my right knee. Simplest place to have it, other locations require the whole centre console to be removed.
    Sep 2014
    Baldivis WA
    Fitted the powerful UK reverse light upgrade kit, what a difference that makes, can see now when reversing.
    Apr 2011
    Wandong,Victoria,Australia
    I removed the rear seat base in my 90 so that the floor folds mostly flat.
    Oh and ticked over 125,000km on the way to work.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Melbourne, AU
    Got back from an 8 day loop Melbourne to Kangaroo Island and back.
    Today was our first long day of 9 hours and what a pleasure it was. So effortless easy and comfortable, truly the best drive I've owned.
    Had a couple of instances of the the 'Emergency braking and lane assist not available' message. Cleared on restart and I kept the cameras and radar cover clean of bugs of which there were many.
    Will check with the GAP tool tomorrow to see if there are any faults logged.
    1996 D1 V8 - gone
    Nov 2015
    Black Rock
    Quote Originally Posted by jwb View Post
    How does the Island look now that it's been a few years since the devastating fires?
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Jul 2003
    I had that happen on a long trip out west. It hasn't happened since. What has the GAP tool revealed?
    Mahn England
    Ex 300Tdi Disco:
    Melbourne, AU
    Quote Originally Posted by DieselLSE View Post
    It was busy where we were but I don't think we went into where the big fires were. Nothing obviously burnt down to Seal Bay.
    1996 D1 V8 - gone
