Results 1 to 10 of 11
Thread: Timing belt life
    Aug 2009
    Sunbury
    Timing belt life
    Our Disco 300tdi is now on club plates and is not used very much these days. The last timing belt change was approximately 50000 km ago, well within the 80k suggested life, but that was ten years ago. I am wondering if age as well as wear is an essential reason to change it, and if so, am I pushing my luck? Considered opinions or experiences would be appreciated.
    Thank,
    Woolly.
    Jun 2013
    Universe A
    Quote Originally Posted by Woolly View Post
    Thank,
    Woolly.
    I think most belts specify age and km, whichever comes first. I'm thinking around 7 years.
    Considering how easy a 300tdi is to do (at least on a defender) I'd be doing it.
    Queensland
    So what is the life in years?
    Say 10 years , is that the shelf life too?
    So it can be on the shelf or in the car for 10 years even unused and its up for replacement.
    Narre Warren South
    Quote Originally Posted by 123rover50 View Post
    In the car it's getting hot when the engine is running, it's under tension and is a bit more stressed than just sitting idle in a box.
    I thought I remembered 7 years as the life, mine was at 9 years before I replaced it ? That reminds me.....when was it last changed ? I must check.
    A lot of the time it's the manufacturer erring on the side of caution.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    the average servicing for a tdi300 is 10K Km or yearly.
    the belt is suppoesed to last 80K Km
    Change the belt every 8th service or every 8 years.
    Sep 2010
    The Hills.
    152.79 MB
    Just to add to the good advice, imo even if the car isn't being used often it's good practice to run it regularly. I know you have a log book to deal with, but if it were me I would risk a run around the block once a month to keep everything that needs oil oily, and to prevent things like belts from forming a "memory". If you have a 90 day book then use the thing to go shopping occasionally. After you change the T belt.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Aug 2009
    Sunbury
    Thanks for all the sound advice and comments; I will tee up a change in the near future, probably by an indie as I don’t have all the appropriate tools and am getting a bit older and less flexible. I often find an excuse to drive it, as I enjoy not being beeped at for imaginary errors like our “ sensible“ car does, and I still think D1s are just about the perfect compromise between ability, comfort and economy.
    Woolly.
    Woolly.
    look me up in the new years.
    Im doing a run up to QLD for xmas with the kids before taking one over to perth, if you want I can get you the kit from MR auto while Im up there and we can line up a change in the late part of january. I can also cast eyes and see what else needs doing.
    As its a disco I usually reccomend doing the P gasket at the same time along with the water pump gasket and the 3 bolts that hold in the p gasket.
    Aug 2009
    Sunbury
    Thanks Dave, pm sent.
    Woolly.
    St Helena,Melbourne
    4.28 MB
    Mine did over 200k on its belt before i sold it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
