Results 1 to 3 of 3
Thread: Ecu flash
    Sep 2024
    Bundaberg Queensland Australia
    Ecu flash
    Hi everyone,
    I have a 2010 discovery 4, I'm wondering if anyone can tell me if you can have the ecu flashed so that when you're in high height the vehicle won't lower over 50km/h?
    Sep 2014
    Baldivis WA
    Hi, no, it can't be done via an ECU flash. The two preferred means are either X-lifter see x-lifter.com or LLAMS, both are plug in devices that allow you to custom set heights, adding to the oem settings. As they are plug and play you can revert to factory anytime by turning them off or unplugging them. The 3rd option is lift rods, but this is more of a hassle.
    Have a search on here, it's a well covered topic.
    St Helena,Melbourne
    1.13 MB
    Or get a Gap tool which you can use to alter the base height or setup 3 preset buttons to use on your phone via an app.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
