Thread: Need new battery for 2013 D4 HSE.
    Apr 2013
    Its finally come time to replace the battery in my D4 again. Obviously don't want to pay for a dealer to do it (like i did last time... boy oh boy $$$!)..... So what should i be looking for with regards to the best brand and places to buy? I've looked at Repco but they don't seem to have much to offer. Any help appreciated.
    Mar 2016
    I previously used an SSB but I didn’t get a good life from it so I switched back to an old favourite of mine, the Varta H3/G14 AGM. Expect however it to cost a little over $500.
    You should use an AGM. You should also reset the battery monitor system after changing it using a GAP tool or equivalent to ensure you get the maximum life out of it.
    2007 Audi RS4 (B7)
    Nov 2015
    Black Rock
    I only use the Varta G14 AGM. Expensive but good.
    If you're down my way I can fit it for you. 'Seasy.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Apr 2013
    Thankyou both for your recommendation. Hubby is capable of fitting it, so i'm going to order a Varta G14 AGM. Do it once, do it right!!
    Jun 2017
    Crows Nest Qld
    It's a shame you are so far away, I took the 12month old one out of my D4 and put the old one in it before it went to the wreckers.
    Les
    Apr 2013
    Quote Originally Posted by LuckyLes View Post
    Les
    Aww.. appreciate the thought!
    Mar 2007
    Kalgoorlie WA
    If you have an Autobarn store nearby, they should have one in stock. I got my current G14 from Autobarn in Kalgoorlie ex stock.
    Cheers .........
    BMKAL
