Results 1 to 10 of 14
Thread: Double beep on lock and unlock
    Jun 2013
    Universe A
    Hi.
    Currently doing a couple things on a 2.7 Discovery 4.
    It has always double beeped on lock and unlock.
    Everything seems to lock and unlock correctly though.
    No faults that I can see in any related ECU's.
    Does anyone have any ideas on how to track down what's causing it?
    I'm guessing a lock related sensor isn't supplying the correct info to the bcu.
    Back down the hill.
    Does the interior light go off when the doors are hut?
    Jun 2013
    Universe A
    They all do after about 1 minute.
    Apr 2012
    Whyalla, SA
    Usally a bonnet closure sensor has failed
    Oct 2016
    Perth, AU
    There is a CCF configuration for arm/disarm chirp. In the Body Control Module.
    Is it possible someone has fiddled with a GAP tool or similar previously?
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Jun 2013
    Universe A
    Would that normally trigger a "bonnet open" warning on the dash?
    Jun 2013
    Universe A
    Quote Originally Posted by veebs View Post
    This is possible but I think unlikely.
    I will investigate for sure though.
    I'm just waiting to sort some diag tool accounts to be sorted before I can pursue.
    Back down the hill.
    Quote Originally Posted by shack View Post
    Doesn't on a D2, yours may differ.
    Oct 2016
    Perth, AU
    Agree, however the open bonnet switch or similar responses here should prevent you from locking. If it beeps but locks, i still suspect the 'chirp' setting
    Mar 2012
    melbourne
    When mine double beeps on trying to lock it due to door or bonnet open it won’t lock
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
