Hi dero,
Sorry to hear your woes.
What sort of temperature are you seeing?
How is it being measured? Standard LR gauge, block or head temp, aftermarket coolant gauge?
When you say it's pressurising, is it pumping coolant out the expansion tank?
Has it being over heating from straight away when the moter was rebuilt? Or was it OK for a while?
When the head was removed for subsequent rebuilds/ head replacement was the head gasket OK? It sounds like head gasket, but seems unlikely with all the rebuilds/heads it's had.
Is the heater blocked off?
Tony
  Reply With Quote Originally Posted by dero
