Results 1 to 10 of 12
Thread: Td5 harmonic balancer.
    Back down the hill.
    Any brand recommendations? I'm a bit disappointed in the Ross I fitted less than 50k km ago.
    Jan 2013
    WA
    Wow thats a surprise you dont hear of many failures, how has it failed.
    Cheers tt
    D2 2004 TD5 Classic
    Back down the hill.
    It's been noisy for a while, now it's shredded the belt.
    Jan 2013
    WA
    That really is a surprise...but saying that I have noticed a little tail tail squeak on shut down from mine.
    50k is way too early, may be worth chatting to Ross performance
    Cheers tt
    D2 2004 TD5 Classic
    Back down the hill.
    Quote Originally Posted by thai_tiger View Post
    IIRC you fitted yours not long after I fitted mine.
    Jan 2013
    WA
    early 2019 ish.....and about 40k klms
    Cheers tt
    D2 2004 TD5 Classic
    Feb 2013
    Queensland
    I have a ross on mt td5 as to date no problems I did have to go down one belt size as the original serpentine belt was just a fraction to big.
    Back down the hill.
    Righto, fan and belt off. It's patently obvious that the failure is the tensioner. New tensioner on it's way from Karcraft.
    The water pump is not leaking, but showing signs of imminent failure, I have a water pump in stock. Is the water pump a doable job on the driveway? Is it in contact with the cam chain? If so, I'm considering a new chain and guides while I'm there. Opinions and advice muchly appreciated
    Nov 2014
    Nirvana near Albany W.A.
    I'll have a guess the water pump is probably OK, and you've been feeling the slack between the drive dogs, before the power steering pump resistance is felt.
    It's pretty hard to tell the bearing state of the water pump without removing the P/S pump first.
    If the telltale in the header tank isn't blocked and is pumping coolant out in a small stream beneath the header tank cap at idle, and it's not leaking coolant out the drain hole in front of the pump then it's probably fine.
    Timing chain is a totally separate job. you can check that and the guides by removing the cam cover.
    Back down the hill.
    Thanks discorevy, that makes the job easier. Is the pump a major job? Is it worth doing as preventive maintenance?
    Are any special tools needed?
