Results 1 to 3 of 3
Thread: Fuel gauge woes
    Dec 2010
    Kiewa Valley, VIC
    Fuel gauge woes
    My [emoji[emoji6Fuel gauge woesFuel gauge woes]Fuel gauge woesFuel gauge woes][emoji[emoji6Fuel gauge woesFuel gauge woes]Fuel gauge woes[emoji6Fuel gauge woesFuel gauge woes]]” fuel gauge is a little puzzling. I believe the sender and all wiring is ok, but the gauge seems to be working incorrectly.
    I just can’t remember where I picked up the gauge, quite possibly at a LR swap meet in England when I was on holiday Fuel gauge woesFuel gauge woes months ago. I’m wondering if it’s a positive earth gauge. Any ideas how to explore this possibility? I don’t have a positive earth battery to check.
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    JDNSW's Avatar
    All Series 1 fuel gauges are "positive earth" gauges, but in fact are polarity agnostic (as are the later gauges).
    However, when the wiring polarity changed from positive earth to negative earth in 1967 (Series 2a) the type of guages also changed from one that operated magnetically to one that works using a small heating element and a bimetal strip. It also needs a stabilised voltage (10V).
    While both types work with either positive or negative earth, neither will work usefully with the wrong sender, and, in the case of the later one, the voltage stabiliser. The two gauges look like they are interchangeable.
    My guess is you either have mismatched gauge and sender, or a later gauge and sender, without the stabiliser. However, if you are certain you have everything correct, the gauges will still misbehave if either the sender (and stabiliser) are not correctly earthed.
    Dec 2010
    Kiewa Valley, VIC
    Thanks John, I think I’m on the right track now.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
