Results 1 to 6 of 6
Thread: ECU programming/marrying
    Jan 2025
    Australia
    Have spent a fair few hours digging through the web trying to find exactly what I would need to marry ECUs, with all the key calculators?
    Can any GAP or Nanocom tools do this? Any others?
    So far, I'm under the impression that SDD with an online subscription to Topix is the only method (ridiculously expensive). I did find some Russians on Telegram offering to set up SDD with Topix server access for a couple hundred dollars, but before I put my favourite pirate eye patch on, I would like to explore more legal options if any are available at less than $3000...
    The reason I need this is to change the transmission control module of a Disco 4. I also have an L494 which I suspect will need things changed out eventually, so would like to avoid VIN locked systems.
    I would welcome any insights people can provide.
    Oct 2011
    Fremantle WA
    Probably initially best to contact Cambo, a member here. He lives in Sydney and is a guru on most things JLR electronic, and I can speak from personal interact that he knows his stuff. Good luck
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Alf002 View Post
    I think it's important to clarify precisely what you mean by "marry" in this context. If it's a case of programming an "identical" second hand ECU to match the car then potentially. If it's trying to do something that didn't come out of the factory then it's a bit more complex.
    Jan 2025
    Australia
    Quote Originally Posted by BradC View Post
    Yes, I would want to program an identical ECU to match. I have done some more digging and believe a Launch X431 Pad V Elite can do what I want, for my budget, without a VIN lock or similar restrictions (if anyone believes I am mistaken, please let me know).
    That said, if I were to use a non-identical item (again, how "identical" do the ECUs need to be?), would the SDD/Topix software be the only option?
    Jul 2015
    Sydney, Australia
    When it comes to 6HP or 8HP TCMs in Land Rovers, they only need the correct software loaded to match the vehicle spec.
    So if you have a 2010 3.0 D4, and you swap a used transmission from a 2010-2012 3.0 D4, it’ll just work.
    If it came out of a Range Rover Sport, then it’ll need programming.
    The VIN in the module doesn’t matter, and anyway the VIN can’t be changed with regular tools.
    The transmission software variant is based on the model and engine type, and power output.
    Example the later 8HP in the Aussie 3.0 D4’s, that is 2013MY 520Nm or 600Nm, and 2014-2016MY 520Nm or 600Nm, so four different versions.
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
    St Helena,Melbourne
    4.28 MB
    So let me get this straight, so I could fit any zf6hp26 box from a tdv6 D3 and it will work without any programming ?
    That goes against everything I have read about them over the last 7 years.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
