Results 1 to 3 of 3
Thread: Trailer brake fuse?
    Jan 2025
    Trailer brake fuse?
    Hi I have plugged my trailer into my 2011 Discovery 4 and have all running lights, tail and indicators but no brake lights?
    I plugged trailer into other car and works fine. There seems to be no power to the plug from the brakes,
    Checked handbook for trailer brake fuse and lists
    11 Trailer reverse lamp
    27 Trailer side lamps
    48 Trailer battery feed
    54 Trailer connector ignition feed
    There seems to be no fuse listed for trailer brake lamps? Any suggestions
    David
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    I am a D3 owner and the brake light fuse is number 1 (7.5A) inside the removable cover in the left hand rear of the vehicle. I.E. open the tailgate and stand behind vehicle and reach in to the left and check.
    I don't know if there are fuses there on the D4. However the info should be in the owners manual if you have one.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    May 2016
    Londonderry, NSW
    There is also a large plug in there so check the wiring as it may be a broken wire from fuse block to trailer connector.
