Thread: TDV6 3.0 Alternator Replacement
    Dec 2016
    Im 99% sure my alternator failed last week and have bought a Denso DAN1105 replacement. I did my YouTube research on steps to remove/replace and it looked easy enough (for a Disco anyway). But my disco seems to have a pipe that runs right under the alternator which is attached to a bracket which makes the unit very hard to physically remove.
    I removed the side panel under wheel arch, got the belt off, all 3 bolts out and could wiggle it around. But where the videos I watched showed, just lifting and tilting the unit forward and down to get to the main battery feed wire and control wire plug, I couldn't get mine to move more than a few mms.
    I also notice the battery wire routes under the alternator, seemingly right up against the bracket.
    Does this look normal to you?
    Here's a screenshot from this video I watched:
    https://www.youtube.com/watch?v=NMsrG_R0_U8
    vs a photo from mine (different angle I know) - but the pipe is much closer:
    Any advice on how to get this out?
    Nuggets
    Discovery 4 3.0L 2010
    Dec 2016
    I succumbed and got an indie to do it.
    Luckily it was the alternator at fault and have a dead one to repair.
    One thing I noticed while he was doing it, is just how close the main feed wire from alternator runs to the ground wire that mounts in the driver side wheel arch - they almost touch! Sure they're sheathed, but seriously?
    Anyway, in and working now.
    Nuggets
    St Helena,Melbourne
    1.13 MB
    Looks like a tight fit, the 2.7 one is a doddle.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    Yeah it’s a **** of a job tbh. I couldn’t for the life of me get the rear connector off Andy ended up cutting the wire and soldering it.
    I don’t miss that job on my 3L. Sadly it’s due again soon.
    2007 Audi RS4 (B7)
    Dec 2016
    It really is a PITA. I hope I don't have to do it again anytime soon.
    The WSM is pretty useless too - or at least the pdf one I have anyway
    Were you able to just lift it and tilt forward DiscoJeffster?
    Nuggets
