 Originally Posted by
TonyC
				Hi,
The thing that let's the motor run or stop is a 12V supply to the fuel injection pump, this wire goes into the rear of the pump.
My guess is your not getting 12V to this except in the start position, check for a good connection and voltage on that wire.
Why did you you add the start button? Has the start contacts in the ignition switch died?
I'm guessing the run contacts have also died.
If the short to the body has killed the switch, I'm guessing you have some poor body earths in the car.
Hope this helps
Tony
 I bypassed mine and ran a separate feed through its own switch hidden under the dash to the injector pump. Slows down thieves to as motor turns over but wont start untill that secret switch is on.
				1963 ex Woomera Ambulance     sold
1950 Tickford Station Wagon       sold
1954 Royal Review                      sold
Perentie 6x6 Forward Control Camper  sold
 1957 SWB Hard top with 200TDI,.
.  1965  2A  Forward Control  Camper.
