I'm not sure of any similarity between the later D4 and the D3. I have a D3, but certainly my 2010 D4 wiring diagram shows they were still similar at that point.
There is an "infotainment" relay which controls power to the screen and amplifier. This is run by the audio head unit (radio) and should turn off power to those devices "X" number of minutes after the car is shut down. From memory, the head is also the MOST bus master.
So in the D3 the head turns on the infotainment relay which powers up the rest of the system. The display then powers up and displays it's boot screen. This remains on until the head unit fires up the MOST bus and tells everything to switch on. The head also manages the steering wheel controls.
If the infotainment relay remains powered, the system remains on but idle.
So it is entirely possible that an issue with the head unit can cause your symptoms.
Now, again the latest docs I have are for a 2010 D4, so yours might be entirely different and this post entirely irrelevant.
