Results 1 to 3 of 3
Thread: I saw this on Facebook running TD5 gear in my series 3 project.
    May 2015
    Williamstown, Victoria
    Hi everyone, I’m running TD5 gear in my series 3 project.
    I’m using TD5 and associated electrics/ecu in my series 3 project. I will need to modify the ecu from Discovery 2 to Series Ute.
    What device or available software would I need to make these modifications?
    Appreciate your comment.
    Will the ECU run as a stand alone?
    Is there an input from the BCU to the ECU?
    Last edited by p38arover; 4th March 2025 at 08:51 AM. Reason: Remove extraneous formatting code
    Build date 11th Oct 2003
    LROCV #1410
    St Helena,Melbourne
    4.28 MB
    I cant help much but a friend of mine converted his RRC/D1 hybrid ute from TDI to TD5 auto, not sure if he still visit here anymore.
    He is likely to be on the FB group though.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nov 2014
    Germany
    35.44 MB
    Hi there!
    All you need is a stand-alone Harness. I know it from Td5inside or Pace4x4. But there ar more who make this harness, i think.
    An ECU, which fits to your engine, the throttle pedal, some sensors around the engine and go for it.
